CompactLogix-Message Instruction Error 16#0009
Coachman
Sep 2006
Maryland
97
I am using a CompactLogix and I am communicating with a generic ethernet device. I am using a Message Instruction and I am getting
a error : 16# 0009 Parameter error in module configuration.
Would anybody have an idea what the cause of this error would be.
Thanks In Advance,
Post more information about the "Generic Ethernet Device". CompactLogix controllers only support the ODVA standard "EtherNet/IP" protocol.
If this device is supposed to support one of the Rockwell-specific functions of EtherNet/IP, we'll have to see the configuration of your MSG instruction.
Hi All, I'm just trying to understand the reason behind something I recently experienced. Background: The system contains 4 CompactLogix...
100
I'm using a 1769-L33ER v20. I need to send a message to a data server with package information (barcode, weight, etc) I've got the MSG set up...
18
6,252
Hello, I'm wanting to read Modbus registers from a Centurion controller back into the 1769-L32E CompactLogix Controller using the "Message" Data...
3,828
I have a compactlogix 1769-L32E, PV600+ and 3 Lenze drives (each drive fitted with a Ethernet IP module) Both the compactlogix PLC and the...
2,028
Hi All, I have a quick programming question I thought you guys might be able to help with. I have a compactlogix controller with 4 powerflex 40p...
2,884
