CompactLogixUSB Port
gbradley
Apr 2002
Corona, Ca.
1,637
Is there an advantage to communicating to CompactLogix with the USB port versus Ethernet?
I've always used Bootp to set the IP address on a new PLC.
Would it be easier to go online using the USB port?
I'm thinking it would.
1769-30-ERM
I find the USB port to be much easier than BootP (when Windows cooperates with the driver). Plug in, once Windows is happy with it, RSLinx will automatically load the driver, you can then set the address from Linx.
Once I set the IP, I switch to Ethernet because I don't like to be tethered with a short USB cable.
I use CompactLogix for development of firmware for EtherNet/IP adapter devices. The beauty of USB is that you can monitor the process data in the PLC without adding additional traffic to the Ethernet communications. In development it is necessary to do a lot of Wireshark capture so the less traffic the better.
I can imagine USB being very useful for development of a PLC application in the lab.
But for most practical applications in the manufacturing environment, USB would be practical only if the HMI is close to the CompactLogix. But even then the USB connector is protruding horizontally, kind of unguarded, whether the LAN connectors are connected from below, kind of better protected. I would say the USB would be useful for a quick check with LogixStudio but not for a permanent communication in the shop floor.
+1 but I also use the flash card a lot when updating the firmware, the flash card is faster and you dont need to sit around watching a bar on your screen as life ticks away
Is there a KB or Tutorial on using the FlashCard for updating Firmware?
Faster is good?
I also gave bootp the boot when the USB port came out. I don’t think I’ve used bootp since. After I have firmware and an IP address set I switch back to Ethernet. Mainly just because I connect many times with a little wireless router so I can freely walk around with my laptop.
Hi All, As a precaution my company has been collecting copies all the HMI and PLC programs. I have recorded copies of most of our sites...
58
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
93
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
228
Trying to export a Modern application for an upgrade to Intouch 2020 but I cannot export the application from the 2014 version because the export...
128
Very similar issue as the last post I had here with communicating our Linux Gateway to an AB CompactLogix controller. I have assigned a gateway...
186
