yuyo Member Y Join Date Jul 2007 Location México Posts 63 Apr 16, 2013 #1 hello I need your help, as I can compress the program and send it to CPU 317 - 2DP from Siemens STEP 7, I have damaged the memory card and the CPU can not run it just to have the memory card, thanks
Jeff23spl Member J Join Date Jan 2010 Location Canada Posts 860 Apr 17, 2013 #3 What kind of backup copy of the application do you have ? The only way i know to load a program to s7 plc is to use step7 or tia software to open it and dowload it to the plc with a working memory card
L D[AR2P#0.0] Lifetime Supporting Member L Join Date Nov 2006 Location UK Posts 6,694 Apr 17, 2013 #4 Try ebay for a replacement memory card - you never you what you might find - here's an example card available in the UK for 35GBP. http://www.ebay.co.uk/itm/Siemens-S...ial_Automation_Control_ET&hash=item3a80411a96 or closer to home: http://www.ebay.co.uk/itm/SIEMENS-6...t=BI_Control_Systems_PLCs&hash=item5aeb092b05 Last edited: Apr 17, 2013
yuyo Member OP Y Join Date Jul 2007 Location México Posts 63 Apr 18, 2013 #5 thanks friends backup load memory card program and resolve it...
