rsdoran
Well we have Six machines but each one has 2 drives. I know I said seven but one line has a brand new machine with hydr positioning on heads. I know of 6 drives in the last few weeks and suspect a couple more from things I've heard. The machines were moved to an addition to the plant 2 years ago. The addition has newer style swithgear on the highside and the entire lines are now feed from busduct (1 duct for 2 lines).
That is changes enough, I agree with Steve first and foremost check the ambient temp and cabinet temp BUT also may want to look at grounding issues and harmonics (I state this because of new machinery installs upline). I have had some major issues recently with power problems causing motor, drive and electronic equipment failure. The facility I am in is old and has some wiring issues BUT even new/moved lines can have issues if there is a weakness in the electrical system.
If you have any recording devices you may want to monitor voltage, current, spikes, sags etc on that BUS and/or the devices. Yes look at the machines first for problems but when its a line of machines look at the source too.
When I was young I got a push from a boss (an electrical engineer that was working as a chief carnival electrician). He told me some simple things, first and foremost...ALWAYS GOTO THE SOURCE. He taught me OHMS law but I didnt realize that is what it was. The difference between silver, brown and green on plugs and how to twist the wires when connecting male/female wires. You know the simple stuff but the foundation that starts a career in an electrical field. The major one tho being ....ALWAYS GOTO THE SOURCE.
