Concat AB to siemens
drip
Jan 2009
canada
59
Hello,
I am fairly new to siemens still and have a customer that has a system in AB and another in Siemens. The code has been created in RSlogix5000 to output the barcode and now I have to do the same for the siemens system. In 5000 a CONCAT command is used to combine the ASCII string needed for the printer with the serial number. I cannot find a similar concat command in siemens and was wondering if anyone new what would the best way to approach this to come up with a solution. Thanks alot for any help!
Hi I am trying to crate a function that needs to join strings together but it wont comile. complaining about the CONCAT code, Illegal parameter...
10,090
Hello, I am fairly new to siemens still and have a customer that has a system in AB and another in Siemens. The code has been created in...
2,127
Hi all I am trying to set up a lhttp instruction to connect to an api https (with our IT) this will send data back to the plc? I have an api https...
1,795
Hello, I am using Machine expert - basic with an M221 PLC. I have two 16 bit modbus registers coming in and I want to convert to a 32bit real...
3,937
I'm writing a new program for a CompactLogix 5069-L310ER. I used a GSV to grab the date and time from the processor. Then several DTOS and...
2,032
