Concept 2.2 - view variable values
Lovell
Feb 2013
Saskatchewan, Canada
120
Hi PLC guys,
I have a file for a quantum controller that was saved a while back.
I would like to view the values of variables at the time of the save.
is this possible with Concept 2.2?
I am not that familiar with concept. I did find where to monitor live values.
There isn't an easy direct way, but there is an indirect way.
Save a copy of the project - this is important since you're going to become "Not Equal" with the controller if you modify anything.
Open the copy and tell it to go online with the simulator instead of the PLC.
You'll be not equal to the simulator - download the program, including state ram, but don't go to run. By not running nothing can change the saved values.
You should then be able to use a reference data editor to look at values.
Trying to identify the Modbus RTU registers that are in use in the Function block programming in the PLC program. I have a Kohler DEC 550...
156
I'm just starting to learn about industrial automation processes, I want to know how a weight feeder unit works which consists of a load cell and...
1,076
We plane to upgrade quantum modicon 140CPU43412A but for upgrade executed , the version must be above or equal v04. When inspect the cpu no v04...
535
Hi Guys, i would need dbconv.exe from Concept 2.2 to convert my plc program to the new Concept 2.6. Unfortunately, I couldn´t find my Concept 2.2...
1,497
Concept of the system (Sketch of system attached) **I am blessed to be a member of this community, thanks in advance** System is a chain...
3,008
