Concept 2.6 -- Program not equal
antsrealm
Dec 2010
Brisbane
207
Sorry I can't add much more detail then what's in the title at the moment. But basically at work we had a program become unequal and now we cant go online to it anymore. I notice there is an upload facility but it does not seem to make the program equal again.
The senior guys are saying they now have no choice but to download the most recent back up to get it equal again. Can anyone advise if there is a way to make the program equal again without preforming a download?
This is a big deal if a download needs to happen. Only a very small change has occurred and was not saved then after a reboot the program was no longer equal.
Thanks.
If you know that a small change was made, then I'd recommend downloading, making the required change and then saving. Depending upon the mix of programming languages used in your program, an upload could be problematic. Early versions of Concept for Quantum PLCs did not support uploads at all.
At any rate, I'd be careful not to overwrite any of your existing backups, should you choose to upload. If your control system is operating properly, then it's relatively safe to assume that your processor does contain a valid program. The worst case scenario would be to upload a corrupt program and save it to a valid project backup.
It's been a while that I can't convert one of my program on concept using concept converter. When I try converting it, it pops an error (ERROR...
1,214
Our company uses Schneider Momentum 171CCC96020 PLC's with our production system to capture press counts. I am using Concept 2.6XL SR6. When we...
4,109
Hi guys. I am tangled in a new software (new to me!) and I am a little stuck on the modbus portion. Here is a description of my problem: I have...
5,348
Trying to identify the Modbus RTU registers that are in use in the Function block programming in the PLC program. I have a Kohler DEC 550...
169
I'm just starting to learn about industrial automation processes, I want to know how a weight feeder unit works which consists of a load cell and...
1,091
