Concept M
Mic
Dec 2005
India
A 984 685 PLC has been programmed with Modsoft v x.xx programming software . The client requires to upgrade the programming software with modsoft concept.
Is it sufficient that I upload the program from 984 PLC to the PC with concept v 2.6 M and download back to the PLC to ensure that the controller has been upgraded from modsoft to concept M. ?
Do I need to configure the PLC ports as one modbus port is communicating to HMI ?
Modsoft was a programming tool for the 984LL language. 984LL can be run in a Concept program section on some processors. An old 984-685 processor is not supported by Concept.
But, to answer your question, yes you need to configure the processor using Concept. This includes I/O mapping and the communication ports.
Thank you Mr.jim Dungar.
How to recognise the concept M supported 984-685 processors ? Can u help me in getting the list of supported 984-685 processors?
Concept M is a medium size package intended for programming the Momentum and TSX Compact families of processors. The original 984 family of controllers, including the 984-685 and 984-685E, is not support by any Concept package. The TSX Compact controllers supported by Concept M include the PC984E258 and larger processors.
Many Thanks for your wonderful support Mr.Jim Dungar
Trying to identify the Modbus RTU registers that are in use in the Function block programming in the PLC program. I have a Kohler DEC 550...
169
I'm just starting to learn about industrial automation processes, I want to know how a weight feeder unit works which consists of a load cell and...
1,091
We plane to upgrade quantum modicon 140CPU43412A but for upgrade executed , the version must be above or equal v04. When inspect the cpu no v04...
538
Hi Guys, i would need dbconv.exe from Concept 2.2 to convert my plc program to the new Concept 2.6. Unfortunately, I couldn´t find my Concept 2.2...
1,507
Concept of the system (Sketch of system attached) **I am blessed to be a member of this community, thanks in advance** System is a chain...
3,026
