configuration of s7 400 & s7 300 plc's for a little DCS system
redautomation
Aug 2013
istanbul
23
please help me to buy a set of s7 400 and s7 300 for my laboratory. we want to have a pcs7 hardware configuration for making a little and low cost DCS system for training PCS7.
Hi
Have you tried eBay or keep an eye out for a factory that may be closing down
These are perfect for demo rigs training rigs etc
Donnchadh
I don't know about which cpu or witch network card's i must buy. I need help to select the minimum requirements for a little DCS system. For example how many cpu??
Which type of cpu??
Whitch network modules???
Hi
Well for the networks in the s7 300 i would look at the CPU that have two ports maybe a
Proifnet and proibus ports, mpi from what I see here is not used very much.
Ethernet is another I would look at. For a traing rig also look at some analogue cards, and as the 400 only worked on a few but again the same range of networks and this would allow you to add I/o and connect the CPU together over the networks
Donnchadh
PCS 7 needs S7-400 PLC's.
You need a number of PC's too, a server, an operator station and an engineerig station.
Do you need failsafe or redundant systems?
So minimum would probably be 3 PC's and 1 S7-400 PLC. I'm not sure but a 417 maybe minimum.
The S7-400 can be a PCI card "slot PLC".
And Siemens sells a bundle kit consisting of a box IPC, with engineering software, operator software, database software all included:
http://www.industry.usa.siemens.com...chures/Documents/e20001-a180-p280-v1-7600.pdf
This is probably the least expensive entry point to get into PCS7.
Last I heard about it it was about 15000 € for such a bundle kit.
Begs to ask: Why PCS7 for a laboratory ?
PCS7 is a DCS system intended for very large process plants.
edit: Didnt notice that you are in Iran. It can be difficult to purchase Siemens parts in Iran.
Hello everyone.Am new in allen bradley configuration,i have a mini project to execute, i have wired my Micrologix 1400 for analog input signal of...
1,502
2,605
Hi Friends, I'm trying to set up/configure a Simatic Net on an already existing project that uses TCP/IP Connection. I formatted the PC-Based...
27
5,142
Hiii, I want to communicate MGate MB3180 to my ML1400 channel0 configuration as my ML1400 as Modbus RTU master. But i need pin configuration for...
1,742
Hello guys, Has anyone on here dealt with the Allen Bradley 1400 series power monitors? At our mill we have several 1400-PD51A ser. A power...
2,344
