configuration of transmitter
anwer
Feb 2012
riyadh
I want to do configuration of ABB pressure transmitter but transmitter model number is not available in hart 375 communicator. my hart has software2.0.
can you give me idea for configuration.
thanks for help
The 375 communicator does 6 to 7 common or generic HART commands for any HART device.
Some of those are
- tag name
- units
- URV
- LRV
- square root or linear
If you need to do more than the 6 or 7 common instructions, then you need to load the DD (Device Descriptor) file for the ABB transmitter.
If there is available memory on the 375, then you load the DD into the 375.
The device manufacturer supplies the DD for any specific model (download it from the manufacturer's web site). I assume Rosemount sells some sort of subscription service for managing DD's on the 375, but I don't have one, so I'm not sure of availability or details.
I've been fighting with a Micromotion 1700. Can't get into the configuration area. It's as if the optical sensors are disabled or locked out...
58
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
69
Hi i using Kinetik 300 2097 driver control by EIP with using move absolute and incremental for motion , but i want to add same driver and motor as...
77
Hello I have a sensor that I read data with IO-LINK but I don't know how to get my data. I see that I have two modes : Process data Map0 and Map...
76
Kindly, we have the following configuration fault on a Kinetix 5700 axis. It only appears when we go online on the Plc. We are just starting the...
118
