configuration the HSCE
zaranet
Apr 2009
Marrakech
firstly excuse me for my english,
In my project, i use the HSCE module, there's tree mode rate, range and sequencer, can you tell me the difference bitween those mode
Range Mode​
In the Range Mode, you define a group of count ranges and define the outputs to be active when the Accumulated Count value is within each range. In this mode, the module offers:​
up to 12 ranges
dynamically configurable ranges
ring or linear counter operation
input rate calculation
direct SLC processor control of unused outputs
Rate Mode​
In the Rate Mode, you define a group of rate ranges and
corresponding outputs. When the Rate Measurement is within each defined range, the corresponding outputs are active. In this mode, the module offers:​
Rate Periods from 10 ms to 2.55 seconds
input rates up to 32,767 Hz in either direction
up to 12 ranges
dynamically configurable Rate Period and range values
Sequencer Mode​
In the Sequencer Mode, you define a sequence of presets and a series of corresponding output patterns. When the Accumulated Count passes the next preset, the outputs are updated to the corresponding pattern. In this mode, the module offers:​
up to 24 discrete steps
dynamically configurable steps
automatic restart at the end of each sequence
external sequence reset control
for my application, I want to calculate the number of tour of a DC motor. so I used it an encoder 845F and module 1746 HSCE, the type allen...
5,023
I've been fighting with a Micromotion 1700. Can't get into the configuration area. It's as if the optical sensors are disabled or locked out...
64
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
69
Hi i using Kinetik 300 2097 driver control by EIP with using move absolute and incremental for motion , but i want to add same driver and motor as...
79
Hello I have a sensor that I read data with IO-LINK but I don't know how to get my data. I see that I have two modes : Process data Map0 and Map...
76
