connect a floppy drive
igor62ill
Jun 2002
Hi.
Can somebody explaine me, how I can connect standart floppy drive
instead PC.I have plug 9-pins from electric cabinet,it can connect
to out device like PC,floppy and ets.But I don't known,which
cables I use for a floppy(one side 9-pins,another-plug of floppy).
Very Thanks.
Hi, We have been facing a issue with SCADAPack 474. Configuration is like below. RTU 474 + 6103 PS + 5606 IO Mix Module + 5414 DI Module Only...
54
335
121
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
149
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
366
