Connect B&R Power Panel to X20 CPU
basilio
Dec 2015
Elets
Hi.
I have B&R Power Panel 4PP320.1043-31, CP1583 and wont to connect it together. I create simple project in Automation Studio for panel only and it work fine, but I can't add CPU.
At next step I try to create "Terminal mode" project for CPU and panel. I make visu, virtual panel and then connect with VNC viewer to CPU. All work fine.
After that, I add 4PP320 panel to project, reassign visualisation and make CF card for panel.
After power up panel start, but every time write "Searching terminal server".
What I do wrong?
PS. Sorry my bad English.
Hi I am using a fx3u enet-l card with a fx3u32m plc. it gets disconnected with PLC after every powerup. any solution? Thanks in advacne
1,502
Hi, We have been facing a issue with SCADAPack 474. Configuration is like below. RTU 474 + 6103 PS + 5606 IO Mix Module + 5414 DI Module Only...
64
340
122
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
153
