connect CPU313C-2DP with ABB Softstart"PST142-600-70"by PROFIBUS network
shaker Hosain
Mar 2010
USA
31
I have CPU313C-2DP , I want to connect it with ABB Softstart"PST142-600-70"by PROFIBUS network.
I set ABB Softstart as following :
Menu --> Setting --> Functional Settings -->Fieldbus -->
Fieldbus control yes .
Fieldbus type Others . //Used for other protocols than AS-Interface
Fieldbus address 4 . // my station address is 4.
Fieldbus auto disable yes.
I used "PDP22-FBP ABB" GSD file, and I used in Hardware Config. of S7 the "Softstart (V01)" module.
I think my configuration is right but I can’t find any connection (STOP light is ON , RUN light is flasher).
what are your opinion?
I have CPU313C-2DP , I want to connect it with ABB Softstart"PST142-600-70"by PROFIBUS network. I set ABB Softstart as following : Menu -->...
2,317
277
101
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
113
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
349
