Connect CPU314 IFM to IM151-1
Peter DN
Oct 2013
Ghent
hi everyone,
I'm wondering if there is a way to connect a CPU314 IFM with only a MPI connection to a ET200S IM151?
I'm used to do it with profibus DP communiction, but this cpu has only a MPI connection (X1 port) and no profibus port.
Is there a way to do this?
thanks for your replies.
It is possible. You have to add a CP342-5 if there is a free slot. If not all 8 slots are used, then it is possible. You then connect the IM151-1 via the CP342-5s profibus port.
But I dont like that the result will be based on a lame and obsolete CPU, the 314IFM.
How many I/O are use in the existing setup ?
I am thinking that a better solution is to switch the CPU to one with at least a DP port, or to go to ET200S with an IM151-8 CPU and Profinet instead of Profibus.
thx Jesper for your reply.
Regarding the very small amount of IO's, it's indeed probably the best solution to switch to another cpu.
this thread may be closed.
309
103
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
121
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
351
What has been your experience with year over year price increases on your Tech-connect service contracts? Is it up to the distributor? 30% seems...
290
