connect Keyboard to PLC
Flurk
Guest
F
HI,
I am doing a little project where I transformed 10 inputs to 4 inputs binair with a multiplexer. Now I want to connect those 4 inputs to my PLC because I want to use it as an alarm, so you have 4 tries to type the wright code.
How would u dou it, can anyone please help.
Everything is welkom, Hints Tips Programs ...... please let me know.
mailto:D[email protected]
Thanks in advance
Try to better define problem and post code you have so far.
What happens after fourth time? Burgler comes and tries his luck
with four (or more) wrong combinations and eventually gives up.
Then you come from work and you cannot enter?
210
99
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
111
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
343
What has been your experience with year over year price increases on your Tech-connect service contracts? Is it up to the distributor? 30% seems...
288
