Connect Modeum To E100
Unregistered
Guest
U
I Need Some Help Please.
I Am Trying To Connect A Duxbury Modem To A E100 The Version Is 6
My Cable Is As Follows
E100 Modem
2 3
3 2
5 5
4 & 6 Are Connected
7 & 8 Are Connected
I Have Even Wired It As Follows
E100 Modem
3 3
2 2
5 5
4 & 6 Are Connected
7 & 8 Are Connected
I Took The Modeum On The E100 And Connected It To A Regular Pc And Using Hyper Terminal Gave It The Following String
At &f &d0 &k0 Q1 E0 S0=1 &c1 &w
Using Hmi Tools Connect I Give It The Following String
At &f &d0 &k0 &w
Baud 9600
Parity None
8 Bits
1 Stop Bit
I Have Checked The Above A Dozen Times, Even Rang Out My Cable.
Using Hmi Connect It Dials The Modeum Answers And The Line Drops Almost Immediatly.
Using Hyperterminal The Line Does Not Disconnect.
P[lease Help
288
102
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
115
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
350
What has been your experience with year over year price increases on your Tech-connect service contracts? Is it up to the distributor? 30% seems...
289
