connect motbus with a delfi application
Bgeerts
Feb 2004
We have the following problem:
We use AV panels to create a man machine interface for a machine, in stead of this panel we are going to use a panelpc. We use a Modbus protocolWe would like to create a low cost connection using the modbus connector of our PLC and the rs232 of our panelpc. The panelpc will run a Delfi application. We don’t know if it’s possible.
Do we need a driver? And where can we find this driver.
If there aren’t any drivers, is it possible to encode the modbusprotocol so we can make our own driver??
The Plc we use is a Modicon Quantum.
[email protected]
Hi, We have been facing a issue with SCADAPack 474. Configuration is like below. RTU 474 + 6103 PS + 5606 IO Mix Module + 5414 DI Module Only...
54
335
121
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
149
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
366
