connect pots and solenoid valve to modicon plc
sambuddha
May 2014
kolkata
can anyone suggest how to connect potentiometer of 10k to plc analog input module..and also how to connect 24vDC solenoid valve to the output of plc
Tell us the complete catalog number of the analog input card you have and the complete catalog number of the output card.
- Digital Input Module (BMX DDI 1602), 16 DI, 24 VDC, Sink
- Digital Output Module (BMX DDO 1602), 16 DO, Trans. Source, 0.5 A
- Analog Input / Output Module (BMX AMM 0600), 4 inputs, 2 outputs, +/-10V, 0-10V,
0-5V/0-20mA, 1-5V/4-20mA
184
97
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
109
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
341
What has been your experience with year over year price increases on your Tech-connect service contracts? Is it up to the distributor? 30% seems...
288
