Connect Rslogix 500 Emulator to hmi
nriver
Feb 2016
Rehovot
Hi everyone.
For my work area i am trying to set up two comouters.
First computer runs ignition hmi
The second one runs rslinx, rslogix and rsemulate 500.
I have already configured the emulated plc and sucessfuly ran my project.
Now i am trying to access it as a device through my HMI and for that i need to assign IP address for the emulated driver. (That way ignition can browse the tags in the emulated plc)
Is it possible to do?
In case not is it possible to connect it to the topic that is pointing to my emulaed driver through rslinx?
Thanks in advance for your help!
I would just switch to Softlogix instead, then you can add an ethernet adaptor to the softlogix chassis and connect to Ignition as you would any other hardware controller.
For Emulate, you would have to setup an OPC topic in RSLinx (assume it's not the 'lite' version), then try and configure Ignition to get data from the RSLinx OPC Server instead of it's own driver. I've never it up like that for Ignition, found Softlogix to be a better platform.
However, depending on what firmware version you are using Softlogix may not be available.
I have rslinx classic and i created a topic name "PLC" and applied it to my emulated plc. But for some reason when i type in ignition PLC as the progid it doesnt connect. I feel like i am missing something very simple here.
Hello all, The title explains what I need, how can I setup WinCC V14 and RSLogix Emulate500 so I can read/write values from the HMI to the PLC...
3,006
Alright, here is what I know. In the lab we are building a new OSIsoft PI system and need to inject some real life data into the machines for...
11,734
Hey there, Currently in school, I gotten an assignment in Technique subject. We are a 4 man group of 3 different skills. A Automation...
22
7,715
I was doing some testing on a Micrologix 1100, and during the test the PLC faulted. Fault light is blinking red. On the LCD, it shows Major...
2,668
I have PLC RSLogix 1000 Allen Bradley and a cable for connect PLC and PC. Becuase have no software for make the programa, I have downloaded a...
5,965
