How to connect RSLogix 1000 with PC
Hiroshi
Jul 2015
Paraguay
I have PLC RSLogix 1000 Allen Bradley and a cable for connect PLC and PC.
Becuase have no software for make the programa, I have downloaded a software as follows.
RSLinx Lite software - needed for online programming
But I could not connect as shown the image attatched.
Please let me know my wrong cinfiguration of the commmunication.
imagen
edit: Oh, I think you were referring to MicroLogix 1000? Can you type the text of the error and describe what you see in the image. I'm not much of an unknown link clicker from a first time poster. No offense. (maybe someone is more bold than I)
Hi thanks.
Yes I am referring MicroLogix 1000.
There in no error message,but in the windows of the comunication, at left appears AB_DF1-1 and no appears nothing.
Just be clear on what you have and what does what.
Your cable should be a 1761-CBL-PM02 or equivalent.
If your computer has a real serial port then this is a straight connection.
If not, then you need a suitable USB to Serial adapter to attach to the above cable.
RSLinx Classic Lite is just a communication tool. It will establish a connection to the controller through the AB_DF1-1 driver which you appear to have created. This will allow you to go online with controllers and perform an Upload or Download of programs via the programming software.
The RSLogix Micro Starter Lite software is the free programming software for the MicroLogix 1000 and 1100 controllers.
Note Well: For Allen Bradley controllers...
When you perform a "Download", this is sending a copy of the program from your computer to the controller memory.
When you perform an "Upload", this is receiving a copy of the program from the controller memory to your computer.
Regards,
George
Hi thanks.
You are right.
I think my PC have real serial port y connect with straight connection.
I will try again next morning.
Thanks again
Hey there, Currently in school, I gotten an assignment in Technique subject. We are a 4 man group of 3 different skills. A Automation...
22
7,725
Hello all, The title explains what I need, how can I setup WinCC V14 and RSLogix Emulate500 so I can read/write values from the HMI to the PLC...
3,009
I was doing some testing on a Micrologix 1100, and during the test the PLC faulted. Fault light is blinking red. On the LCD, it shows Major...
2,672
Hi everyone. For my work area i am trying to set up two comouters. First computer runs ignition hmi The second one runs rslinx, rslogix and...
3,863
hi guys can any one help me with correct procedure to connect RSlogix5k to logix5561 plc step by step. i am using ENET ethernet module. 1. can...
5,405
