How to Connect WinCC Basic V14 With RSLogix Emulate500
Grendizer
Apr 2012
Toronto
88
Hello all,
The title explains what I need, how can I setup WinCC V14 and RSLogix Emulate500 so I can read/write values from the HMI to the PLC?
Thanks,
WinCC Basic only works with the "basic" panels.
And the basic panels have an Ethernet/IP driver for Allen Bradley.
So maybe it can work with a simulated Ethernet/IP connection. I have never tried it though.
Side Note:
Under Options/Settings/Online & diagnostic then the "Default connection path for online access". It is the type of interface selection. Can that be used to create an interface type that will accomplish what I am looking for?
Side Note:
"Default connection for online access" is used to remember defualt settings for downloading or going online with PLCs and HMIs (basically, is there one port on your PC you prefer to use?)
I have no idea how to connect Emulate to ethernet, or if it even can be.
If you're setting up a Simulated HMI on your PC, You go to the PG/PC interface in your Portal PC, and select the Ethernet interface of the .
If you are just setting it up for a real basic panel, you create an EIP connection, and enter the IP parameters like any other PLC. Again, assuming that Emulate can talk to Ethernet.
Hello everyone is it possible to connect the studio logix5000 emulate to a siemens wincc 7.5 running on another pc? if so, what do i have to do...
499
Hi everybody. Please help me. i want to know is it poosible to write SCADA program for a CJ2M-CPU31 OMRON PLC in WINCC program? Programming of...
1,415
Hi guys, Could i connect simatic WinCC runtime with Micrologix 1400 PLC via Modbus?
1,246
Hello, I'm working on set up connection between OPC Kepware V5 (running on PC A) and WinCC V7.0 (running on PC B). Basically OPC (as server) to...
4,252
Hi I need your help I want know that how many stations(wincc,op panel ,..) can connect to a plc S7-400 cpu417. According Technical...
2,297
