Kepware WinCC V7 connect
putiss
Sep 2015
Czech Republic
54
Hello,
I'm working on set up connection between OPC Kepware V5 (running on PC A) and WinCC V7.0 (running on PC B). Basically OPC (as server) to collecting data from PLCs and WinCC (as remote client) showing data.
In WinCC Explorer... I add the OPC driver and OPC connection and then when I want to connect to remote OPC DA via Test Server button, I'll get pop-up:
"Server is not active, cannot be reached by the computer network or does not support the OPC interface!"
Somebody with experience with it?
Could someone give some info what is necessary to setup connection?
Thank you :)
@hmirie - you have to install OPC Client connectivity pack at the same server where wincc is running. Then you can connect wincc v7 via OPC DA
To import data from wincc (PC B) to OPC Kepware V5 (PC A) you need to define wincc as an OPC Server and not client "Wincc OPC Server".
In the other side, you need install OPC Server that could work with your PLC ( such PLC have it's own OPC Server, OPC Server for PLC Siemens doesn't work with PLC Allen Bradley )
@allexkym - thanks for opinion. I had an idea that I can use Siemens OPC Client Scout (part of WinCC V7 package) but kepware with UA tunnel (pc A - pc B) works good
@Oubax - PC A is defined as server. It means point where I collect data from different type of PLCs. PC B with WinCC app is just station which is connect to PC A via OPC UA tunnel.
...without DCOM setting :)
I have a strange Kepware issue I have been dealing with for a few weeks. I have Kepware setup with the Omron NJ Ethernet driver and reading in...
102
Hi All, I am after some assistance setting up kepware to take tag data from an FX5U PLC, I have tried many many port numbers and still cant get a...
167
Im trying to get data from AB guardlogix controller using Kepware in a remote location but it seems that version 6 can only support contrologix...
444
Hi, Have anyone came across issue with Kepware or Linkmaster not returning correct values (Unknown Quality) for some tags From OPC DA Client...
684
I’m attempting to configure KEPWare to poll a Modbus device via Modbus TCP/IP. However, everything I’ve tried results in an error being reported...
422
