Kepware V6 and AB
s9k2004
Jul 2015
Riyadh
19
Im trying to get data from AB guardlogix controller using Kepware in a remote location but it seems that version 6 can only support contrologix.
Has anyone tried it even using an old controller?
Seeking for a guide..
thanks
Which guardlogix controller are you trying to use? Even Guardlogix is just the name for the controllogix which is rated for SIL-x or PLDx standards.
Kepware should be able to interface with most AB PLCs.
Good day..
I am trying to get data from 1756-L71S Guadlogix 5570 safety controller. Based from your input, I tried to revisit my work to reconfigure it using contrologix controller and reading the right syntax. Luckily i got it.
Thanks for your input.. I can now mixed datas from allen bradley to siemens for OPC use.
I have a strange Kepware issue I have been dealing with for a few weeks. I have Kepware setup with the Omron NJ Ethernet driver and reading in...
98
Hi All, I am after some assistance setting up kepware to take tag data from an FX5U PLC, I have tried many many port numbers and still cant get a...
158
Hi, Have anyone came across issue with Kepware or Linkmaster not returning correct values (Unknown Quality) for some tags From OPC DA Client...
674
I’m attempting to configure KEPWare to poll a Modbus device via Modbus TCP/IP. However, everything I’ve tried results in an error being reported...
412
Im using Kepware for comms between a Panelview 1250 and a power transducer via modbus tcp. Im a little confused on the Kepware software, Im using...
842
