Can i connect Wincc v7.5 to a OMRON PLC?
rezarahnama
Dec 2022
Tehran
Hi everybody.
Please help me. i want to know is it poosible to write SCADA program for a CJ2M-CPU31 OMRON PLC in WINCC program?
Programming of OMRON PLC is done in CX-ONE but i want to connect wincc to this plc as scada. is it possible? if yes please give me the instruction.
thanx alot.
Hello and welcome to the forum.
I think the only possible way to do this would be through OPC UA (or the previous OPC DA) technology. The WinCC SCADA has support for OPC UA (and OPC DA) Client functionality. Unfortunately Omron newer PLCs have OPC UA server capability, but not the CJ2M-CPU31. So you would need a middle-ware that can convert from the OPC UA client in the WinCC to the FINS server in Omron. There is a Japanese company called Takebishi which offers a middle-ware that runs in Windows which can do precisely this. If the Takebishi middle-ware and the WinCC run on the same PC, then you do not need OPC-UA. I think you could configure the legacy OPC DA which may be cheaper for both WinCC and Takebishi. The middle-ware license should be several hundreds of euros. It may be possible to download an evaluation version to test the product, but I am not sure about this.
I think this might be possible as I looked into it also. I would have to check that project to be sure though & what strategy/protocol I was going to use
If I remember, I’ll have a look next week & try to post back
Hello everyone is it possible to connect the studio logix5000 emulate to a siemens wincc 7.5 running on another pc? if so, what do i have to do...
499
Hi guys, Could i connect simatic WinCC runtime with Micrologix 1400 PLC via Modbus?
1,245
Hello all, The title explains what I need, how can I setup WinCC V14 and RSLogix Emulate500 so I can read/write values from the HMI to the PLC...
3,007
Hello, I'm working on set up connection between OPC Kepware V5 (running on PC A) and WinCC V7.0 (running on PC B). Basically OPC (as server) to...
4,250
Hi I need your help I want know that how many stations(wincc,op panel ,..) can connect to a plc S7-400 cpu417. According Technical...
2,293
