Connect S7-PLCSIM with Beijer OPC Server using NetToPLCSim
sivkat
Nov 2009
Norge
Hi!
I have tried to establish a connection between S7-PLCSIM and Beijer OPC Server using NetToPLCSIM, all of these are installed on the same computer.
In the NetToPLCSim window it says: PLCSim: Connected. Client: Disconnected. How can I find the client? In Beijer OPC I have created a controller (S7 ISO over TCP/IP) and entered the IP-address of my computer, but it doesn't seem to work.
What have I done wrong?
Regards
Sivkats
the OPC-Server connects to your PLC (or Nettoplcsim) only when a client is connected.
So use an OPC test client or start your client software.
Your settings of the IP address are OK.
To do a simple test, add an item to your OPC server (e.g. MW0) and then select "Write Tag Value" in the context menu of this item. Then the server should connect without a client.
Thomas
Hey, I have Intouch 10.1 SP2 running on one PC and Siemens S7, NetToPlcSim, and S7Sim on another PC. Is it possible to connect the two PC's...
2,903
Hello, Does anyone know how I can get on OPC server (Kepware) to speak to the S7 PLC simulator? I use the simulator regularly with WinCC and...
2,298
How can i connect ifix3.5 with Simatic 5.4 plcsim (simualator)... I have already connected simatic plcsim and wincc 6.2.... i have no idea with...
1,611
Hi, We have been facing a issue with SCADAPack 474. Configuration is like below. RTU 474 + 6103 PS + 5606 IO Mix Module + 5414 DI Module Only...
47
333
