connect Siemens PG P4 to sinumerik 810
bri@zf
Aug 2006
Maine
I'm trying to connect my Siemens field PG P4 to sinumerik 810 to view and edit the S5 program and having problems. Interface set to "Com 1 standard", using 25 pin - 25 pin cable: 6FC9344 4RB00 with interface cable: 6ES 7798 1BA00-0XA0, baud rate set at 1200?? I think.. com 1 standard. I have setting data 5010 as 00000100, SD 5011: 11000111, SD 5013: 11000111. and pressing data in start twice to show"interface busy".. I get PLC Timeout message after a few seconds... I read a previous thread but am not sure what to do next. Do I have the right cables? Do I use the LPT or PLC program connection on the interface cable? Any help will be appreciated.
175
Sorry for the basic question: At the moment, the PLC [S7-1200] is connected to a laptop (contains TIA Portal) via the ethernet port. When I add...
1,506
Hi Complete newcomer to S7 so go easy on me... Siemens S7: What cable do I need to connect S7-1200 PLC to HMI? The touch screen is one of these...
2,606
Dear guys, I have a software that sends data to PLC using modbus. I want to connect my software with siemens plc, how can i do that?
19
4,685
Hi - I have an application where we are planning using an Edge device to connect some equipment, likely an S7-1500 and WinCC Unified Comfort...
947
