Connect Siemens PLC via Ethernet to PC
Mar 2012
Auburn
Hello forum,
I am attempting to get a Siemens S7 - 300 PLC connected to our network, that way we can pull data off of it as necessary. Since the PLC does not have a ethernet module, we will be adding a Simatic Net Module (CP 343-1 Lean).
What we are trying to accomplish by doing this is, after the PLC finishes testing a part, we want to record the data using Excel 2010 and have it stored. We have already accomplished this task using Allen-Bradley PLCs and RSLinx using DDE links in Excel 2010. Now, we are trying to do the same thing but with Siemens S7 PLCs.
Thanks for your help!
Thanks for the reply!
Is there a step by step walkthrough on how to setup the OPC server somewhere? I have no experience with OPC servers. I also do not know what Softnet S7 Lean is nor do I know how to install/use Softnet S7 Lean. Any detailed help or links to sites/threads would be great as I do not know what needs to be done in order to accomplish our goal.
We looked at the various methods of achieving this and in the end used a Redlion datastation for ease/cost.
You can then use excel on the CSV file created.
Redlion can also communicate via MPI,Profibus of your existing CPU and has ethernet built-in
291
Sorry for the basic question: At the moment, the PLC [S7-1200] is connected to a laptop (contains TIA Portal) via the ethernet port. When I add...
1,515
Hi Complete newcomer to S7 so go easy on me... Siemens S7: What cable do I need to connect S7-1200 PLC to HMI? The touch screen is one of these...
2,611
Dear guys, I have a software that sends data to PLC using modbus. I want to connect my software with siemens plc, how can i do that?
19
4,723
Hello guys, I have a siemens PLC and i want to add a new preocess without touch the Siemens code, so i am going to add Delta PLC, this PLC will...
5,909
