Connect signal to PLC and DeltaV???
Mar 2012
Cork
Hi there!
I was wondering if anyone out there could tell me if it is possible to connect a 24V signal (from a sensor) to both a PLC (Siemens 1200) and a DeltaV controller simultaneously? I'm not talking about using Profibus communication or protocols of any kind, just literally connecting the same signal to the digital inputs of both controllers.
Thanks.
I haven't seen that in practice. If both are sourcing, or both are sinking, and if both are using the same DC supply, and you don't have issues will pull-up or pull-down resistors it could work. Do you have the option of one receiving the input and sending the signal to the other ?
Since this is a descrete signal it should be possible to run the two in parallel. This isn't any different than using one signal to light a pilot light and turn on a PLC input. Just make sure your polarities are right, and that you have a return path for the - side.
Hey thanks for your replies. I thought that it might work, it seems pretty simple after all. My only concern was that this signal may somehow connect the two incompatible systems.
I doubt it will work, Delta-V has sinking digital inputs, the absence of voltage is a logical 1, most other systems are the reverse. I know Mitsubishi PLC's used to work this way too, but I have not used them in many years. An interposing relay with two output contacts might be required.
330
118
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
141
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
363
What has been your experience with year over year price increases on your Tech-connect service contracts? Is it up to the distributor? 30% seems...
298
