Connect Sinking Analog Sensor to Delta Analog Module
Mray
Mar 2018
Toronto
90
I am working on a project with Delta PLC for the first time. I want to connect a Sinking analog sensor (4-20 mA) to a Delta analog module (dvp06xa). I am in doubt that whether it is possible or not. Please help me to figure it out.
Please see the attached photos as:
Photo #1 = Sensor wiring diagram
Photo #2 = Sensor pin out
PDF = Analog Module Manual
  • DVP06XA-S.pdf
175
95
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
107
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
341
What has been your experience with year over year price increases on your Tech-connect service contracts? Is it up to the distributor? 30% seems...
288
