Connect Stratix 5700 Switch (Software Update problem)
huhu0901
Feb 2022
Naju
hello guys.
I'm using 5 Stratix 5700 Switches
4 of them make DLR(Device Level Ring)
And one of them software version is not matched 15.2(6)E1 and another is 15.2(6)E2a
I want to make 5 unit DLR
I tried to software update to 15.2(8)E1 so I make unit's software version is all matched
I downloaded tar file from rockwell homepage
I tried to software update using device manager (like 192.168.1.201)
I try to update 4 unit (left 1 unit)
But i'm waiting over 2 hours. that is not completed
so i think it is already done but is not reflected.
(not move from level 3, 1%, extracting the software file)
(loading tar file to the switch and verifying the tar file is done )
when i tried to software update in switch if i finished this job Guide say i need to close and reopen the browser.
so i close the browser and i access again.
at that time possible to access so i turn off the system.
but few days later i turn on and try to access it is not possible.
and switch which i try to update are not possible. other one is okay
and 4 unit EIP Mod led green flashing (Okay one is EIP net led green flashing, EIP Mod led green solid)
So i try to express setup but it is not work too.
Finally i try to access the switch using console port using rj45-usb cable and hyper terminal
this is can be possible to access? am i trying right way??
Good evening all, Going forward, our IT group wants us to use managed switches in the machines we network with. I installed a managed switch...
2,701
225
101
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
113
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
345
