Connect X20CP1483 to PC via Ethernet
Buibatruong
Dec 2022
Phu My
Hi everyone, i have problem to try connection X20 CPU via Ethernet.
I using AS 4.7 with licensi 90 days trial. I go Online>Setting> scan network but PLC not appear in device list. Anyone could help me to get the setting connection by using ethernet cable? Thanks
Is the PLC running a program? Are you able to factory reset it and try to reconnect?
An X20CP1382 I just set up did not have SNMP enabled by default so it could only be found on initial setup when it was still using DHCP for its IP address.
241
101
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
113
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
347
What has been your experience with year over year price increases on your Tech-connect service contracts? Is it up to the distributor? 30% seems...
288
