Connecting a Flex-Pro metering pump to a PLC via Ethernet module
plcscout
Jun 2015
Missouri
Hello, i'm trying to connect a metering pump to a 1756-L61 ControlLogix5561 Controller. I have the metering pump and anybus module hooked up correctly but when I try to either use the 3rd party EDS file or a Generic Ethernet module file in RSLogix 5000; I continuously get the same module fault "(Code 16#0128) Connection Request Error: Invalid input size". I've tried changing the data types and changing the input size to 8,16,31, and 32 bytes. The third party EDS file uses an input assembly of 100 and an output assembly of 150 which is what I've been using for general ethernet module. configuration assembly is set to 1 while the size is set to 0 as none is used. Does anyone have any ideas? also if more information is needed I can provide it.
That is the configuration that I have used for ABC (with Data - SINT)
The problem is most likely with with configuration of the ABC. The input and output assembly configuration is set on the ABC for the amount of IO you need to exchange.
Make sure that the numbers at each end match.
Hello everyone, I am trying to upload some parameters from a powerflex 523, and download them to a new powerflex 4. First problem is I’m not...
597
Hello everyone, I am new to this site and relatively new to PLC have had a few college courses. I am now working on my Masters Capstone Project...
1,945
is it possible to comunicate a powerflex 753 (ccw) using ethernet 20-750-ENETR card to a panelview plus 6 1250 (factorytalk view studio me)...
1,498
Good Evening Everyone, I tried to find pick through the forums and found some similar problems, but could not find quite what I was looking...
5,696
im looking to connect with my laptop by serial port and drive explorer w/ rs1 adapter, i have the adapter and my ab dealer says to use a null...
2,075
