Connecting Emulated HMI to Emulated PLC
SCREAM2003
Nov 2015
CA
Hello,
I'm currently working on a project with RSLogix500 and Vijeo Designer for my HMI. I use RSLogix Emulate 500 to host my PLC program while working from home for testing, and have a setup for running my HMI in an emulated environment, however, I cannot get my simulated HMI to connect to my emulated PLC. How can I accomplish this?
RSLogix 500 Emulate can emulate the serial port on the SLC-5/0x controllers, so you could use two physical serial ports, or as noted a virtual serial port connector (I've experimented with com0com as well).
Emulate 500 doesn't support emulation of the Ethernet or DH+ or DH485 ports on an SLC-500 controller.
You could also use a licensed OPC server version of RSLinx Classic, with the Emulate 500 driver, but that's probably outside of the scope of this setup.
Thanks Ken. I am using a MicroLogix Controller but I assume that the same would be true as to Emulate500 not supporting Ethernet, DH+, or DH485?
Also, my HMI project is currently setup to communicate via ethernet.
I only have the Lite version of RSLinx Classic. How can I get an activation file for OEM or Single-Node?
That's right; Emulate 500 is unusual that it supports a DF1 serial port, but not Ethernet.
Unless your HMI can easily be switched to being an OPC Client instead of using its embedded PLC protocol drivers, OPC isn't feasible. I think RA might only sell licenses for RSLinx for "Gateway", having commercially retired the others.
I think you're going to have to wait until you have the physical PLC in order to test the HMI.
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
48
93
Hello, I was looking to store some values from our FactoryTalk Application using Datalog to a MariaDB. I see there is quite a bit of documentation...
102
I haven't encountered problems connecting to a PLC through VM Ware but I am with this particular machine. I'm running Windows 7 on a Windows 10...
235
Hi, I want to build a demo station to test devices and programs and I need some help with it. I want to connect GuardLogix, Piltzmulti and...
149
