Connecting PV 550 through RS232 where as it has DH485
Feb 2007
home
66
Dear Folks,
I have to trouble shoot a panel which have one SLC 5/03 PLC and one PV550. I can communicate with SLC 5/03 using USB to RS-232. But the issue is how can I communicate with my PV 550. Is there any thing like Passlink, can it work for.
Regards,
Husnain Mahmood
I dont know what is going on. I tried the way this manula has given but it is not working.
Once agains I will tell what I have and what I dont
1- SLC 5/03 OS 301.
2- PV 550 With DH485
3- USB to Serial Converter cable for Communicating with SLC 5/03.
Now what I did was I setted the bit S34 0/6 and enabled the pass thru communication. Then in RSLinx I tried to find the PV 550 but it did not worked.
I was connected to SLC on channel 0. Channel 0 is configured as DF1 Full Duplex. PV 550 is connected on channel 1 whic is configured as DH485 at 19200.
The problem is I want to upload the programme running in PV 550 as I dont have the backup copy.
Regards,
Husnain Mahmood
A simpler and surer method would be to use a memory card to upload the application.
But, to get passthrough to work, you may need to shut down RSLinx and restart it after making the changes as you did above. Sometimes RSLinx will not browse correctly following a change to its configuration. Also, be sure that you expand the SLC processor in the browse window to look for the PV550 as one of it sub-ordinates in the tree.
Hi guys. I'm working on building some screens for the pv500. The program is currently running in the SLC 5/01. I'd like to get my laptop online...
2,806
Hi guys!!!!: Do you have tips or any information to connect a Panel View 550 to PLC 5 via DH+?
4,895
Hi This may be a simple operation ... but I just can not connect SLC505 (1747-L552) and PV550 (2711-T5A20L1). I have absolutely no...
8,344
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
84
94
