dcorrick
I have a machine that was made for our company by an outside vendor several years ago, and I want to go in and modify the program. The system has a Micrologix 1500 controller, the 1761 NET AIC interface which drives a panelview 550, the side DB9 connector on the 1500 is driving a Quartech device which is driving two AB Ultra 3000I Servo Drives. I have tried to connect into the 1761, which was set to auto, and I changed it to 19000 baud, but RSlinx will not see the device. I can connect the same cable and PC to other 1500's in the plant, and have no problem communicating with them. Do I need a different driver or cable to connect through the 1761? I want to be able to go online and make changes while the machine is running. Any help would be greatly appreciated. Thanks
