Connecting S5-135U to a TP270
Opsys
Jun 2004
Hello,
This is a great forum i hope somebody can help me?
I want to connect a touchpanel (TP270) to a Step5 (S5-135U)PLC but i want to know how i can program the S5 to communicate with the TP. I there somebody that have a Function blok of S5 that provides the communication ?
All help is very very very welcome
Are you going profibus or AS511?
With AS511 you dont need an FB. Just cable it up. Profibus- you do.
I just used the AS511 to PC cable- the same cable you use to program the S5 with. (its a current loop type) Then in protool use the S5 driver. Set up your comm. settings. It actually very easy.
Hello again,
So if i'm correct i only need to set up my communication settings in the Protool part?
So when the settings in protool are correct I only need to make a tag that is linked to data in a DB? Or do i need to do some more before i can read some info from a DB that i'm using in my program?
I am upgrading an old version wincc to V7. I want to use AS511 communication. Can I communicate 2 S5-135u cpu's to my WINCC SCADA runtime using...
2,021
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
44
89
Hello, I was looking to store some values from our FactoryTalk Application using Datalog to a MariaDB. I see there is quite a bit of documentation...
102
I haven't encountered problems connecting to a PLC through VM Ware but I am with this particular machine. I'm running Windows 7 on a Windows 10...
235
