Connecting S7-200 to a TP177 micro
adfox
Jun 2006
Poland
334
Hi I've got a problem, I need to connect S7-200 (unknown type) with TP177 Micro. What cable should I use for a distance o 10-15 meters ? Will MPI or PPI cable work with older type of CPU?
TP 177 order number is 6AV6640 - 0CA11 - 0AX1
Regards.
Hello all. When I try to connect to a S7-1200 PLC (Tia Portal v17) which has a CP 1243-1 module that is connected to my clients network I get...
1,521
Hi there I am new with this thing and i don't know how to connect Allen Bradley Micrologix 1200 PLC to Raspberry Pi using USB to RS485 in NodeRED...
2,283
Hello all, I'm working with an s7-1200 and a stepper motor in Tia portal v17. This stepper motor is an SMD23E2 and I am attempting to connect...
19
2,861
Hi All, I have a closed loop stepper motor (Nanotec make), https://en.nanotec.com/products/2512-pd4-e601l42-e-65-4. This uses MODBUS TCP for...
3,885
Hello all. I have to connect to a Siemens S7-200 CPU 224-XP using a serial connection with DB9 to USB converter. The converter is connected and...
3,449
