connecting S7-400 project to WinCC 6.0 with MPI
kas_
Guest
K
Hi all :)
I am a little noob on WinCC and i would kindly ask you all for some help.
At my plant we use WinCC as the main control system.
The only work I do with it is adding buttons, process values and alarms.
But I`m trying to teach my self how to build upp a project from the ground up sort of speak.
But I`m haveing a problem with connecting to the PLC.
I got a Siemens S7-400 PLC on my workbench I would like to connect my project to with MPI.
I did like described in sheet 27-30 "WinCC getting started". https://support.automation.siemens.com/WW/adsearch/pdfviewer.aspx?HitsPerSite=10&ehbid=17356933〈=en&nodeid=17413658&siteid=cseus&query=WinCC%20getting%20started&page=1&view=new
But have noe connection to the plc when I startthe project in runtime.
Sow too the 10k$ question, does any one have a "for dummies" how-to connect wincc project with a PLC with MPI to share with me?
Software:
WinCC v6.0
Step 7. v5.4 sp4
Hardware:
S7-400 416-2P
Kind regards
kas :)
In the Manual, from page 25 to 27, you create a WinCC MPI connection to your PLC. From page 27 on, you create all the tags inside the MPI connection you just created.
Hi nonuke, sorry I did mean page 25 to 27, i just writed the PDP viewer page number.
When i open the Drive Diagnostics in wincc i got no connection..
I have a Micrologix 1400 to which Ive assigned a specific IP address. Now when I am trying to configure it in Rslinx, i cannot find it under...
37
10,502
Hello, I wish to connect a Micrologix 1400 PLC with a Wonderware SCADA application. I have RSLinx Classic Lite. Is there any other way than...
1,198
Hello, i am an mechanical engineering student but have been asigned to find and test different methods of connecting a scara robot (Toshiba THL400...
2,184
Do this happened to any of you ? I just succeeded connecting a ml1400 true a new XPmode VM by the means of ethernet. I used a direct cable from...
3,690
hello every body I want to connect ifix5.0 to s7-400(cp443-1) with sl4 driver.do I need to install simatic net or not?
1,786
