Connecting to DH485 port on SLC 5/03
Eradicated
Sep 2013
Berlin
Hello everyone, I have a question about connecting to an S500 PLC.
I have been tasked with going to site and taking a backup of a program from an AB S500-series PLC (5/03 processor, actually a version by ProSoft with built-in Modbus Slave functionality).
I have never worked with these PLCs in the past and have very limited experience with Allen-Bradley in general.
I have the software (RSLogix500 Pro and RSLinx), so I should be good on the software side of things.
However, there are two ports on the PLC:
1) RS232 Port (standard DB9 connector)
2) DH485 Port (8P8C/RJ45 connector)
I know I could use either of these to connect to it, however the RS232 port is in use all the time, i.e. it is configured as a Modbus slave and a SCADA system uses it to retrieve data from the PLC. I might not get the permission to disconnect it during my site visit, so I might have to use the DH485 port.
Now the main questions:
a) Can I use a standard USB-to-RS485 converter to connect to the PLC using the DH485 port, or is it a different electrical interface? In other words, do I need a dedicated cable from AB or can I use a generic RS485 one (like ADAM)?
b) If I can use a generic RS485 adaptor, does anybody have a wiring diagram that I could use to connect to this port?
I would appreciate your help!
Hello,
No its not RS485 its DH485.. the part number you need is a 1747-UIC, if you can not find them locally we sell them
If you have a serial port on your PC you maybe able to use a 485/232 adapter but not if you are trying a USB also
Ok, thank you for the info.
It is a pity, though - I know that DH485 is really just a comms protocol which can utilise different physical interfaces.
I was hoping that the RJ45 port on that CPU really uses RS485 as the electrical interface, but if I need a dedicated adaptor, then it seems it is an AB proprietary interface of some sort?
I will have to search for the adaptor on eBay, then.
DH485 is both electrical(RS485) and protocol(DH485)
The above mentioned 1747-UIC is both a electrical converter (USB to DH485) and protocol converter (DF1 to DH485)
There is no driver in RSLinx that would support the Adams (like) device. That I know of.
AB gurus please correct me if I'm wrong.
Some of the Allen Bradley legacy cables are quite expensive. If you're lucky you might be able to get away with using a USB to Serial connector like what is used for Micrologix 1200's connectors (RS232 to DB9 Connector) they are much cheaper. I know you said that port is in use but I think it's probably your better option. Two $20 cables instead of one $70 to $400 cable https://www.plccable.com/allen-bradley/ I think the ones you want are on that page and the AB Factory sealed one's price is kind of ridiculous.
Hi all, I have a SLC 5/02 that's been gathering dust for the past couple years that I want to have some fun with. The only problem is I don't...
3,899
Dear Folks, I have to trouble shoot a panel which have one SLC 5/03 PLC and one PV550. I can communicate with SLC 5/03 using USB to RS-232. But...
4,709
Hello all, I had an old machine come back in for some work. The system has an SLC 5/03 which connects to a PanelView 600 through it's CH0...
8,184
I am working on project where I have to connect one SLC 5/03 to Two Workstations and two MODBUS controllers, on DH485 NETWORK. I am using protocol...
3,524
Hi everyone, I have a slc 5/03.. and this one uses the dh485 for communication. It currently has a pv 550, also using he dh485...
2,022
