Connecting to Micrologix 1500
mdeltat
May 2007
Los Angeles, Ca
84
What hardware do I need to connect to a micrologix 1500 and load a program from my laptop? What cable and do I need to go through a PCMK or PCC card or will the COM port suffice? If using a serial cable, do I use a straight through or crossover? Thank You
mdeltat said:
Can I use a 1784-pcm5/b through a 1784-pcmk/b communication card? Or just a 9-pin d-shell serial cable?
9 pin d-shell serial cable.
Does your ML1500 have one port or two?
The above mentioned cable (1761-CBL-PMO2 is a null-modem cable)
If your ML1500 has two ports the one on the side (9-pin), any null-modem cable can be used.
Does your laptop have a real serial port? If not, you can use a USB to serial adapter."Keyspan" is a good one see link below to get one.
http://www.plctrainer.net/
See link below for set-up
http://www.mrplc.com/kb/index.php?article=65
99
We are in the process of upgrading (by force) our wired system to a wireless system. We have numerous pump stations and tanks throughout the city...
4,454
Hello I am trying to connect my computer to my mocrologix 1500 plc. I have 3 plc's connected with an advanced interface controller(AIC). I have...
20
5,739
Here is my problem... I have taken a PLC beginner course and a PLC intermediate course... But both courses focused heavily on programming. Now...
7,176
I am currently working on a project in my CTC screen to connect to Micrologix 1500 PLC. I have been unsuccessful in getting the two to talk. I...
3,645
