Connecting to old PLCs throw serial
Which USB-to-Serial converter will work depends a lot on the brand and model of the PLC.
Buy the Omron USB/serial converter and save yourself a lot of grief. It is expensive but has been tested and works with all Omron PLCs - and anything else I have ever tried.
Failing that if you will not pay the money I would make sure the converter has an FTDI chipset inside - they appear to be far more reliable and connect to more devices than any other I have ever tried. The Omron one has an FTDI chipset.
Thanks for the replies
I will try to but the cable from OMRON
And regarding the old PLC's from ABB? Will the keyspan do the job?
Thanks,
Bruno
I believe you will find the Omron one will do the job - I have never had a fail to connect or any dropping out with mine to anything.
Hello again!
I have found a printed copy of the ABB PLC program. But I woul like to confirm if it is the same that is on the machine!
Does anyone have the ABB 907 PC32 software?
I have search it but did not find it.
Thanks,
Bruno
Dear all, In a previous post I asked if someone had the software for an old Taian TP02. We used to sell our bandsaw machines with these PLCs a...
2,783
I've been resurrecting an older machine from 2005 and have had good success with help from the forum. Got connected to the PLC and was able to...
1,392
Hey folks! I spent a week trying to figure the problem out but no luck. Please, give any advices, guys. I have: 1) Old ABB Advant AF100 OPC...
6,225
Hey guys, I'm trying to connect my laptop to an old SLC500 PLC. It has a DH-485 port on it and I have to configure a driver for it on taking. I...
1,382
Hi folks We have recently revamped an old S5 based control system to S7 type. Before,level2 (which is running on a PC with DOS operating system)...
2,761
