Connecting to Siemens s7-200
sobrio35
Mar 2015
Vancouver, WA
Hey all,
Trying to go online with an outdated Siemens s7-200. I have the correct cable I believe (PPI Multi-Master Cable - PPI-RS485 on one end, PC-USB on the other) but my laptop is not registering it. We have Step 7 - Micro Win version 4.01
I've tried like mad to find a driver for the cable but without success. Anyone have experience with this?
Thanks!
Hey all,
Thanks!
You don't have to have a driver to use the PPI cable.
Take a look at screenshot, if Siemens MicroWin is installed correctly it will create your driver.
For the MultiMaster cable it will not show up in your device manager as a COM port, it will show up as a Simatic device, with your device manager open unplug the cable... if your screen blinks and you hear a tone then its loading/unloading, if you see a yellow exclamation mark then you have a driver or hardware issue and you need to look at the details of the device
Set your PG/PC and choose USB in the details ~ see the attached procedure on setting it up, I think it should help
Hi All, I have a closed loop stepper motor (Nanotec make), https://en.nanotec.com/products/2512-pd4-e601l42-e-65-4. This uses MODBUS TCP for...
3,896
Hi everyone Does anybody know if it's possible to connect a termopar to an analog input directly? being more specific Siemens S7-200 analog input...
1,688
Hi, I am having trouble connecting to a Siemens S7-200 PLC in Citect. - Citect Version: 6.1 SPB, - Driver: SIMPPI 1.00.03.001 - Siemens...
2,689
This may seem a daft question but I am having trouble connecting my laptop to an S7 200 plc. On my old computer (win 98) I uase the serial ppi...
2,817
Hi guys, I'll be doing 2 projects using Siemens PLC, S7-200 and S7-300. Can someone please let me know what is the correct programming...
1,961
