Connecting to subunits on a siemens S5 PLC
yogiontour
Jun 2011
Salisbury
Hello chaps.
Have a small problem. How do I go about connecting to a PLC that has been set up as in the attached diagram? I have no problems connecting to the standard set up but I imagine this will require a different connection configuration in Step5?
Cheers
Hello chaps.
Cheers
The jpg was to unsharp for me to be able to read the comm-card numbers. I thougt I saw two 942 cpu's in the fog, and they can be connected to Step5 with the 'normal' current loop converter.
Kalle
I think (but am not sure) that the two CPU racks is in some kind of redundant configuration via the IM304-IM324R.
I would believe that you could just use the regular TTY cable connection to the PG port on either CPU.
Comments:
1. Do not try to make any modifications to this system unless you know exactly what you are doing !
2. As soon as possible, this system should be totally replaced by something newer that has a chance of being supported. I think a candidate is S7-400H in a redundant configuration.
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
40
85
Hello, I was looking to store some values from our FactoryTalk Application using Datalog to a MariaDB. I see there is quite a bit of documentation...
97
I haven't encountered problems connecting to a PLC through VM Ware but I am with this particular machine. I'm running Windows 7 on a Windows 10...
230
Hi, I want to build a demo station to test devices and programs and I need some help with it. I want to connect GuardLogix, Piltzmulti and...
149
