Connecting Ultrasonic sensor with Micro850 PLC
hamzkh
Aug 2013
Auckland
22
I want to use an ultrasonic sensor with Micro850 PLC. Is there any cheap sensors that I can use for distance measurement?
Is this a university project or a real world application? You need to define what "cheap" is. To me, cheap is less than $1,000 when talking about ultrasonics.
What are you measuring and what sort of vessel is it?
I agree with Saffa, most industrial grade ultrasonic sensors won’t be cheap. I have used the BEP marine ones here successfully...
http://www.bepmarine.com/en/ts1
They have a 0-5V output option, but you’ll need the programmer to change the default 10-180 ohm setting.
Regards,
Rob
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
40
85
Hello, I was looking to store some values from our FactoryTalk Application using Datalog to a MariaDB. I see there is quite a bit of documentation...
97
I haven't encountered problems connecting to a PLC through VM Ware but I am with this particular machine. I'm running Windows 7 on a Windows 10...
230
Hi, I want to build a demo station to test devices and programs and I need some help with it. I want to connect GuardLogix, Piltzmulti and...
149
