Connecting WinCC to Toshiba PLC
Ken Roach
Apr 2002
Seattle, WA
17,490
I received the following PM this morning from new member navid007, writing from Tehran:
Connecting wincc to other PLC such as Toshiba
Hi , How can i do that , is it possible with opc channel ?
I presume that WinCC uses ordinary OPC Servers as data sources, as do most visualization software packages.
My company competes directly with Siemens and Toshiba, so I am not a good source for information on those products.
Hello, I'm Alex from Spain (sorry for my bad english). Firstly, I'm a newbie at Siemens PLCs and HMI, I have been reading this forum for hours...
1,609
I'm trying to connect Wincc Flexible 2008 Advanced into SQL Server 2005 via script. For the test I made a db in the SQL as db_kalup and created a...
7,282
Hi, i am beginner with WinCC and i need help, i connected the Temperature transmitter with a SM331 module on PLC so i can read a temperature value...
4,118
I am upgrading an old version wincc to V7. I want to use AS511 communication. Can I communicate 2 S5-135u cpu's to my WINCC SCADA runtime using...
2,026
Hi Guys! I have two S7-300 PLCs which are redundant using Siemens Software Redundancy and I need to monitor the data of those PLCs in one HMI...
2,189
