Connecting Wincc Flexible RT with ST300 with PROFIBUS
rizo88
Jul 2017
Málaga
Hello,
I'm Alex from Spain (sorry for my bad english).
Firstly, I'm a newbie at Siemens PLCs and HMI, I have been reading this forum for hours learning a lot of interesting things. You're knowledge is amazing guys!
Regarding my problem, I have a system with an S7-300 PLC, connected via PROFIBUS to a PC with a WinCC Flexible RT HMI. The other day I was trying to install an OPC client and I have messed up the communications.
I have been trying to follow this manual:
https://support.industry.siemens.co...nCC_flexible_Kommunikation_Profibus_V10_e.pdf
Some information about the situation:
- I don't have STEP7 but NCM PC but as far as I know this shouldn't be a problem.
-I don't have an HMI project, I just have the .fwx RT file.
- I'm using a CP5611.
-In the SIMATIC NCM PC Manager I can't insert an SIMATIC HMI station.
I'm trying to follow the guideline but I get blocked at this point.
My first question is, is this guideline what I have to follow? Why can't I insert an HMI station?
Thanks in advance! :site:
This is too open-ended to provide advice.
Any advice may push you in the wrong direction rather than helping.
You need to know exactly how the profibus connection is setup in the WinCC Flexible project.
Investigate that, post your findings here, and then we can help further.
Hello Jensen, thanks for yout fast reply.
The main problem is that I'm not able to open the WinCC project. I just have the .fwx. There is any other way to know that?
What I only can see is the Station Configuration Editor (attached).
I know it is too open-ended, but I'm totally lost.
I'm trying to connect Wincc Flexible 2008 Advanced into SQL Server 2005 via script. For the test I made a db in the SQL as db_kalup and created a...
7,256
Hi Guys! I have two S7-300 PLCs which are redundant using Siemens Software Redundancy and I need to monitor the data of those PLCs in one HMI...
2,171
I have a PLC project. In the same project I have a touch panel 177B. I can simulate the PLC in PLCSIM and start the runtime simulator but they...
7,145
Hi, i am beginner with WinCC and i need help, i connected the Temperature transmitter with a SM331 module on PLC so i can read a temperature value...
4,097
I am upgrading an old version wincc to V7. I want to use AS511 communication. Can I communicate 2 S5-135u cpu's to my WINCC SCADA runtime using...
2,018
