Connecting wincc flexible 2008 to PLCSIM
PDS
Jul 2009
Belgium
I have a PLC project.
In the same project I have a touch panel 177B.
I can simulate the PLC in PLCSIM and start the runtime simulator but they don't communicate with each other. Is there an extra option or something to select or something ?
Wincc flexible 2008
PLCsim 5.4
The S7ONLINE access point set on the PC must match what is setup between the TP177B and the PLC.
In the latest version of PLCSIM, you must select the 'PLCSIM' version of the driver you intend to use in Set PG/PC Interface. For example S7ONLINE = PLCSIM(MPI), S7ONLINE = PLCSIM(PROFIBUS) or S7ONLINE = PLCSIM(RFC1006).
In the older versions of PLCSIM, it only worked with MPI. In that case you should use S7ONLINE = PC Adapter (MPI). If you use ethernet or Profibus between the TP177B and the PLC then you can not connect to the older PLCSIM.
Hello, I'm Alex from Spain (sorry for my bad english). Firstly, I'm a newbie at Siemens PLCs and HMI, I have been reading this forum for hours...
1,603
I'm trying to connect Wincc Flexible 2008 Advanced into SQL Server 2005 via script. For the test I made a db in the SQL as db_kalup and created a...
7,264
Hi Guys! I have two S7-300 PLCs which are redundant using Siemens Software Redundancy and I need to monitor the data of those PLCs in one HMI...
2,177
Hi, i am beginner with WinCC and i need help, i connected the Temperature transmitter with a SM331 module on PLC so i can read a temperature value...
4,115
I am upgrading an old version wincc to V7. I want to use AS511 communication. Can I communicate 2 S5-135u cpu's to my WINCC SCADA runtime using...
2,025
