Connection lost with CP 243-1
mulderm
Jun 2003
Netherlands
298
Hello,
I have a Siemens s7-200 plc (CPU222) and a CP 243-1 ethernetmodule.
Most of the time when I will going online using MicroWin I get no
connection with the CP 243-1 and sometimes I get good connection.
When I going to the communications option and I click on the refresh than sometimes I get "unknow" adres and "not connected".
The leds on the CP 243-1: Run and Link leds are green.
When I using a ping command always I get response from the
CP 243-1.
The cable is correct.
When sometimes I have connection (led cfg is yellow) then the
communication stay's good.
When I going offline and try online again then there is again no
connection.
Who recognise this problem?
Greetings,
mulderm
When E300 powered off, the ethernet device tag data stayed at last know state, for example, fault bit is still Off, ready bit is still ON, status...
1,016
I'm working with a 1734-AENT PointIO module (manual) connected to a 1769-L30ER controller over fiber ethernet. The 1734 PointIO module has some...
1,051
Hi all I am working on a retrofit project. There is one backup pump with Powerflex 753 drive controlled by 2 different PLCs(one 1756-L63 ,one...
1,536
Hi Experts, One of our clients, until recently, could connect remotely via the internet to a Siemens TP1200 Comfort HMI via VNC and **** Cosy...
1,587
Good afternoon! Please help, the following situation happened: Connected encoder Siemens 6FX2001-5QN25 with Profinet IO to PLC S7-1200. The...
1,108
