Connection of floating level sensor with PLC s7-200 CPU 226
Connect the first wire to that terminal and the other wire to the second terminal...oh and if there's a third wire then connect it to that other terminal...does that help? :)
If you would like other people to help you may need to give more information (manufacturers details/part no. etc). Is it a 2 wire or 3 wire sensor? Is it configured for 0-10V or 4-20mA (or even 0-20mA)? Which analogue expansion module are you trying to connect to?
The more info you provide the more detailed the replies will be. :oops:
Regards,
Rob
specification of floating level sensor
>Float type
> Switching voltage: Maximum Voltage: 240 VAC\ 200 VDC.
> Switching Current:2A
>Two wire
>Bottom plate fix and upper plate moving
>works using magnet
Sounds like a discrete sensor. How you wire it up depends on how you wired up your PLC. Basically this float switch will operater the same as a pushbutton and will wire to your PLC the same way.
Know this is kind of vague but without more detail it is the best I can do.
I have got an Rockwell PLC 1769-L36ERMS . I have assigned a IP address to it . But every-time I Reboot the PLC it looses Communication to my PC...
67
Hello all! So I have one project with a S7-1214 and a MTP1500 "Project1" and one project with another S7-1214 "Project2". Both of these PLC:s need...
88
Hi dear . I have a system with cj1m cpu11 etn. previously NT 5z HMI was connected with plc. recently my old HMI got damaged. I want to replace it...
278
Hello gentlemen, Im working on a small project on TIA Portal, about establishing a Modbus TCP connection between my ET200SP plc and a socomec...
332
Hi all, My ethernet port on my laptop recently broke and I was hoping to just use a usb-c dongle in the mean time to go live on my PLC until I...
465
